Mindray - BC-5800
by Mindray
Hematology analyzer
The BC-5800 Auto Hematology Analyzer provides values for medium-sized labs. Responding to increased demands for high quality read-outs and accurate diagnostic decisions, BC-5800 provides a reliable chemical dye method, complete 5-part differential menu and re-exam rule customization. With the high test speed of 90 tests per hour and touch screen operation, BC-5800 serves as one-stop workstation and streamline routine workflow in a hematology lab.
-laung laung
Tue Aug 18 2020
RBC and PLT histogram
Currently we are doing interface with mindray bc-5800 via hl7 protocol. As we know the analyzer include 4 image files, two histogram and two scattergram. For two scattergram, the analyzer send as ^Image^BMP^Base64^ format so we can simply decode to the image file. But for the histogram the analyzer send as ^Application^Octer-Stream^Base64, thus we didn't know the format of the file to decode with. Is any other option or method?Reply
2
-laung laung
Tue Aug 27 2019
RBC histogram
I want to make analyzer(mindray bc-5800) send me the histogram data as application/BMP/base64 (bitmap data) but currently send as application/octer-stream/base64 (binary data) format. Did I need to change something like setting of the analyzer.
  • Laser scatter differential to ensure outstanding accuracy
  • Semi-conductor laser scatter to differentiate white blood cells by cell size and granule complexity
  • Patented cluster algorithm to separate cell groups with great precision
  • Intuitive flagging information to help determine abnormal samples
  • Fast throughout and increased walk-away automation
  • Optional 2 types of autoloader with 50 or 100 tubes capacity
  • Supports both whole blood and capillary blood samples
  • 90 tests per hour throughput
  • STAT test in open vial mode
  • Touch screen operation
  • Large color touch screen to access routine functions
  • Standard DMS software for enhanced data management
  • Supports Bi-directional LIS connection
  • Enhanced diagnostic power
  • Re-exam rules to pull out abnormal samples for further checking
  • Supports microscopic results input on final report
