BIOTEX S.A. - BlueX PantOs DG XP
The PantOs DG xp is a digital panoramic x-ray system equipped with a specific detector for diagnostic imaging.
It has high resolution, high sensitive CCD sensor and it can read 4096 levels of gray for maximum definition in the images. The system is easy to use with automatic image acquisition displayed on the computer screen and there is no need to wait for films to be developed.
The PantOs DG xp is a compact unit supposed to fit into every dental studio. It can be either fixed to the wall or stand by itself using a self-standing base, which is available upon request.
The PantOs DG xp has an intuitive control panel showing 7 types of panoramic examinations and 4 patient sizes. The technical data are provided automatically once the desired program and patient size have been selected. If required, the values can be changed manually.
To facilitate positioning of the patient three laser beams, a mobile front mirror and a motorized system for carriage translation are provided.
The OrisWin DG Suite is a user-friendly visualization software for direct visualization of radiographic images which have been acquired from the PantOs DG xp. Workflow optimization can be achieved by the management of patient data, the display of images and implant planning all in one software.
FORUMSView All (3)
0Repliesa year ago | Error 13, error 21 1. J Error 13 38 V DC supply out of range Check the value with a volt meter on the test point of the Power Supply Board and replace it if the value is not in the range 34 to 42 V. Voltages are Ok , I have measured it and its 36Volts. This error seldom occurs... Q Error 21 No tube current No or low anode current. This error can be caused • by interruption of High Voltage power supply (right side of the Power Switching Unit board) • or by interruption of the filament power supply (left side of the Power Switching Unit board) • or by interruption of the driving circuits (in the regulation board) • or by fault in the tube-head (input transformer or multiplying circuits). Check the supplying circuit in the bushing (multi-pole cable) and the flat cable between the regulation and power switching boards. On the Power Supply unit check the switch SA 301 (must be ON), fuses FU 304 and FU 305. If they are OK, switch exposure and check the driv- ing signals for HV regulator and inverter (points 1, 2, 6 and 7 on the Regu- lation Unit) and the HV inverter supplying voltage (between points D3 and S5 in the Power Switching Unit) – should be in range from 50 to 100 volts (depending on kV and mA setting). Then measure the primary circuit of HV transformer. If all is correct, the circuit between the secondary of HV transformer and tube is broken. Depending on the location of the fault, consider to replace the Power Switching Unit board, the Regulation Unit board, the connecting cables or the tube-head. This error can be also activated by sparking in the tube, when a very short over-current signal switches off the HV regulator only, but is not trapped by the Control Unit in order to activate error 17. In this case try to perform the tube seasoning (de-gassing by making a number of exposures at low kV) or replace the tube-head if necessary. This is difficult to find. I am currently trying to check the cabling.... Any ideas further?Reply |
1Reply2 years ago | Problema de no tomar Rayos X Manual de servicio en Español Reply |
0Replies5 years ago | calibration PantOs DG from Bluex company I need help support for calibration PantOs DG device from Bluex company, so please I wait for any attention Reply |
