Siemens - Multix Swing
Ideally suited for the complete range of routine examinations.
MULTIX Swing Fit for purpose. Easy to use. MULTIX Swing is a compact, cost-efficient radiography workplace based on a cassette catapult bucky. As a reliable, easy-to-use solution, MULTIX Swing is especially suited for all acquisitions of skeletal radiography of the recumbent and seated patient:
Orthopedic diagnostics trauma, routine and ER diagnostics thorax diagnostics The simple-to-use system minimizes training time, allows efficient workflow and speeds up your patient throughput.
FORUMSView All (9)
0Repliesa year ago | Multix Swing Hi dear sires What type of flat panel detector can we use instead of Drx-1Reply |
0Replies2 years ago | Alarm. The x ray have door alarm so it can not perfom its function how can i remove the alarmReply |
2Replies2 years ago | error code 009 i need service manual for this machine Reply |
