Medtronic - WarmTouch WT 6000 Warming Unit
A convective warming unit with an intuitive screen showing the temperature and status of each of the five temperature settings.
Maintaining normothermia has never been so easy.
The WarmTouch convective warming system provides an easy solution for maintaining normothermia. The WarmTouch convective warming unit has an intuitive screen showing the temperature and status of each of the five temperature settings. The soft but strong WarmTouch blanket is tailored for most surgical procedures, offering tear resistance, even airflow, and patient comfort.
1Reply2 years ago | wt6000 certificate hello i would require the ce and fda certificate for warmtouch wt6000 warming systemReply |
10Replies5 years ago | Servicemanual Hallo my Name is Patrick, i Need a servicemanual for the WT6000 Warmtouch. Have anyone this ?Reply |
- Easy to use - A new, intuitive LCD screen and menu function provide all information at a glance.
- Easy to control- Five different settings, including ambient and boost, are offered for more flexibility and precision.
- Easy to handle- It is lightweight, making it easy to transport and attach the unit to a cart, bed rail, or an IV pole.
- Easy to service- The onscreen filter expiration warning makes it easy to maintain and service the unit.
WARMING UNIT | |
Size | 24 in. x 17 in. x 12 in. (60 cm x 43 cm x 30 cm) (hose fully collapsed, nozzle in storage position on unit) |
Weight with power cord | 5.2 kg (11.5 lbs) |
TRANSPORT CART (OPTIONAL) | |
Weight | 3.1 kg (6.8 lbs) |
Height | 67.1 cm (26.4 in.) |
Width | 32.3 cm (12.7 in.) |
Depth | 38.6 cm (15.2 in.) |
ELECTRICAL REQUIREMENTS ENVIRONMENTAL | |
Power requirements | 100 to 240 V AC |
Max. current at 100 V = 8 A | |
Max. current at 240 V = 5 A | |
Input frequency | 50/60 Hz ±1 Hz |
Fuse (x2) | Littlefuse (mfr.) 0218010; 250 V, 10 A |
Temperature | 18°C to 28°C (64.4°F to 82.4°F) |
PERFORMANCE SPECIFICATIONS | |
Maximum contact surface temperature | 44.1°C (111.4°F) |
Average time for contact surface temperature to rise from 23°C ±2°C to 37°C | 6 minutes |
Average time for temperature of air exiting the hose to rise from 23°C ±2°C to 37°C | < 1 minute |
Accuracy of displayed temperature | ±1.0°C (air entering hose) |
Automatic temperature step down (boost to high temperature) | After 45 minutes of continuous use, blower will step down from the boost to high setting. |
Thermal protection threshold | Thermostat (internal) 49°C to 55°C (120°F to 131°F) |
Average alarm level | 56 dB @ 1 meter |
