Dosis M&M - Koolio
An Optimal Air Cooling System
Koolio is an optimal air cooling system dedicated for before, during and after the laser procedures without interfering laser beam emission. Koolio is designed for reducing pains and thermal damages might be happened during or after laser treatments, and for temporary topical anesthetic relief of injections.
1Reply2 years ago | Manuals Hi I am chasing an instruction manual for this machineReply |
2Replies5 years ago | Koolio -Air cooling system not working Hello All!! i am facing issue in Koolio -Air cooling system not blowing air.Number 3(Level) 3(Timer) blinking on display . make:Dosis M&M Model:Koolio Please help me out if you have any service manual. Reply |
- Powerful cooling air temperature
- Intelligent air flow control system
- Auto self-detection controlling system
- Continuous compressing for an immediate use (standby mode)
- Self defrosting system for the best cooling performance
- 9 variable cooling fan speeds for various selection
Electric shock protection : Class I equipment, Type BF applied part
Electrical device class by IEC : Class Iia
Input rating : 230VAC±10%, 50/60Hz
Power consumption : 2500 VAC in max.
Therapy air flow : 9 level (max. 1000/min.)
Power input : 1KW
Mode : Start / Stop(pause) / Stand-by / Defrost(Auto)
Treatment tube : 2 meter
Display : FND Screen with touch button
Dimension : W330mm x L750mm x H795mm
Weight : approximately 60kg
