Getinge - 533HC-E
by Getinge
Series Steam Analyzer
Getinge 433/533HC-E Series Steam Sterilizers deliver an unmatched combination of sterility assurance, cycle flexibility, real-time information access and advanced operator control. These sterilizers are ideal for new construction or replacing older models, offering increased chamber loading capacities within the same wall openings and footprints of your current units.
An updated touchscreen display makes it easier than ever to custom name cycles for fast, accurate identification. The 433HC-E and 533HC-E Series offer cycles employing either gravity/downward displacement or pressure/vacuum pulsing. The sterilizers offer up to 24 cycles in two easy steps for applications including wrapped and unwrapped porous and non-porous hard goods, utensils, gowns or towel packs and liquids in self-venting or unsealed containers.
FORUMSView All (17)
-Som3a
7 days ago
Getinge 533HC
I have getinge 533hc, it display an error CE door not closed, and the steam boiler not workingReply
-Som3a
7 days ago
Service manual
The device is out of order, and l need the service manual
Equipment: Getinge - 533HC-E
-RenaJ76
3 months ago
Turning back up boiler on
Can anyone walk me through proper steps in turning on the back up boiler on?
  • Optimized for OR/Point-of-use Sterile Processing, Central Sterile Processing (CSSD) and surgery centers
  • Avanti touch panel control interface
  • Multiple shelf adjustments for larger loads
  • USB port standard for downloading back-up cycle performance
  • Gravity and Vacuum Steam
  • H 21″ (965mm) x W 21″ (965mm) x D 38″ (532mm)
  • Chamber footprint 9.7 Cu Ft (275L)
  • Validated Load
    • 3 trays (12 fabric)
  • Tray Weight (lbs.)
    • 25
  • Load capacity (lbs.)
    • 75
