SSCOR - Duet Flat Back Model 2314
Instant, Powerful, Portable Aspirator
FORUMSView All (4)
1Reply2 years ago | suction unit not working on battery unit work while plug on powerReply |
1Reply2 years ago | Technical Manual I need parts for repair. Do you have a Parts ListReply |
4Replies4 years ago | NECESITO MANUAL DE SERVICIO TENGO PROBLEMA CON UNA TARJETA ELECTRONICAReply |
SERVICE COMPANIESView All Aspirator Companies
- AC suction unit
- Battery back up
- When fully charged at full capacity, 45 minutes +/- 10% running time
- >30 lpm clinical airflow
- Fully adjustable vacuum regulation between <50 and >525 mmHg
- Dual mode charger activates when plugged into AC power source
- Drops to float when fully charged
- Clearly labeled battery level
- 1 year warranty, 3 year battery replacement
- Lightweight: 10.05 lbs/4.55 kgs
- Large easy to use handle
- Can be customized to fit your canister
- Sealed lead acid battery
- CE listed
Performance: | >30 lpm clinical airflow, <50 mmHg to >525 mmHg vacuum |
Dimensions: | 9" H x 5.25 W x 17 L (22.9 cm H x 13.3cm W x 43.2cmL) |
Weight: | 10.05 lbs/4.55 kgs |
Charger: | Internal dual mode charger activates when connected to AC power, dropping back to float when battery reaches a full charge. LED's indicate charging status and remaining running time. |
Battery: | 12v DC Sealed Lead Acid Battery |
Run Time: | 45 minutes +/- 10% when battery fully charged at full capacity |
Input: | 100-240V AC, 1.0-0.5A, 50-60 Hz |
Output: | 40 watts 12V DC 3.3A |
