Siemens - Hema-Tek 2000
by Siemens
Slide strainer
The HEMA-TEK 2000 Slide Stainer provides a continuous-feed loading platform that eliminates wasted time associated with batch staining methods. Correct first-time staining means less duplicated work. The pilot light indicates when remaining solution is sufficient for only 20 slides. Main functional components are spiral conveyors and three peristaltic pumps. Pumps deliver fresh reagents in precise volume for every stain while the platen provides uniform stain from field-to-field and slide-to-slide with stain and buffer mixing accurately and uniformly. Slides are immediately available for viewing upon completion of staining, and the rinse reagent contains the optimal alcohol concentration for proper slide drying. Dials, located on front panel, allow for wide variation in stain intensities to suit individual needs. This tried and true slide stainer is capable of staining 60 slides per hour.
FORUMSView All (3)
-BrineBiomed
Fri Mar 28 2025
Where to source Gear assemblies from in 2025 and beyond
Was looking for a place to purchase the gear assemblies or if someone knows if Siemens changed the part numbers when they purchased them from Bayer.
-sbheme
Thu Oct 20 2016
Parts
I am looking for a replacement drawer for my Hematek stainer, I do not want to buy the whole unit, only a drawer(would probably purchase two, as we have a back up unit that is also missing a drawer). Thank you
-mirene
Tue Dec 11 2012
question about a scaner
hi i would like to know if u guys have tha dura 352 mv tube and how much is it?
  • Pumps deliver fresh reagents in precise volume for every stain while the platen provides uniform stain from field-to-field and slide-to-slide with stain and buffer mixing accurately and uniformly
  • Slides are immediately available for viewing upon completion of staining, and the rinse reagent contains the optimal alcohol concentration for proper slide drying
  • Dials, located on front panel, allow for wide variation in stain intensities to suit individual needs
  • Simple to maintain
  • Stains 60 slides per hour
  • Delivers precise volumes of fresh stain for every slide
  • Platen ensures uniform staining from field-to-field and slide-to-slide
  • Stain and buffer mix accurately
  • Rinse reagent contains the optimal alcohol concentration for proper slide drying
