Siemens - Acuson X600
by Siemens
Ultrasound System
The ACUSON X600™ ultrasound system delivers a new standard of "standard" ultrasound, integrating sophisticated ultrasound technologies into a nimble, fleet-footed fighter for excellence in General Imaging, OB/GYN, and more.
-amir kaka
a year ago
Need Service manual
When i try to switch it On the device tries to start by flashing on the keyboard and Goes down without showing any thing on the display .
Equipment: Siemens - Acuson X600
-feelingsmonk
4 years ago
Keep on rebooting
My X600 reboot automatically 2 seconds after startup or during application start up, it keeps on rebooting when it was cold startup,but once it start the application successfully then no more reboot. We've tried to replace the AC-DC assy , replaced HDD and disconnect the probes but didn't solve the problem. Your advice is appreciated, thanksReply
Advanced Imaging
Siemen's pioneering imaging technologies aren't just reserved for higher-end systems. Even when designing an affordable system, we begin with an advanced imaging engine to deliver quality where it counts. The ACUSON X600 system supports excellent image uniformity throughout the entire field of view, allowing you to fuel your clinical performance across a wide range of applications with insights based on clear, high-resolution images.
Built to Work Smart
Efficiency, like all critical things, is an innovation that must be engineered. It requires thoughtful integration of sophisticated tools designed to streamline workflow, enhance ease of use, and boost efficiency before, during and after procedures. The ACUSON X600 system incorporates innovations such as knowledge-based workflow tools and available QuikStart rapid boot to deliver the efficiency, practicality, and flexibility demanded by shared-service healthcare.
Progress and Protection
The best protection for your ultrasound investment is the ability to take advantage of technological progress. The ACUSON X600 system continuously benefits from software and hardware upgrades pioneered on higher-end systems. With advanced features provided standard, as well as options for customization, this cost-effective, core system can evolve and adapt for years of critical service across a wide range of applications.
