Haier - Upright ULT Freezer
Upright Freezer
This product is specially designed and manufactured for long time storage of various biological products, including viruses, germs, erythrocytes, leucocytes and cutis. Applications can be found in blood banks, hospitals, epidemic prevention services, and research institutes, laboratories in electronic and chemical plants, biological engineering institutes and marine fishery companies.
3Replies5 years ago | Locked Mode We have just replace the temperature probe in a Haier Upright ULT freezer. It has only cooled to -16C. The "locked" light is illuminated. We are unable to UNLOCK by pressing the "up or "down" key and then adjusting to "06"(the password) and then pressing the "set" key for 3 sec.Reply |
SERVICE COMPANIESView All Biomedical Freezer Companies
- Reliable Performance: Cabinet temperature can reach -86°C
- Temp uniformity within 6°C
- Energy Saving: Four independent inner doors and four-layer sealing structure, having good heat insulation to reduce energy consumption.
- Low Noise: World-leading refrigeration cabin design to reduce operation noise.
- Cooling performance: -86°C
- Temperature Range: -40~-86°C
- Capacity: 828L
- Storage capacity: 600 x 2" Cryoboxes
- Interior Dimensions(W*D*H): 870*716*1310(mm)
- Exterior Dimensions(W*D*H): 1145*980*1980(mm)
- CFC Free Refrigerant
- Noise Level: 50 dB
- Vacuum insulation panels
- Ambient temperature range of 10°C ~ 32°C
- LED display
- 4 Insulated inner doors
- 3 shelves
- Test Hole
- 5 years warranty on compressor
- Functions: High/Low Temperature, Remote Alarm, Hot Condenser, Power Failure, Sensor Error, Low Battery, High Ambient Temp, Door Ajar
- password
- Ergonomic design
- CE and UL Certificate
