Olympus - OFP-2
Flushing Pump
The Olympus OFP-2 pump delivers power and control that can irrigate fluid via either the instrument or auxiliary water channels of endoscopes. This allows the washing of gastric and colonic mucosa during procedures for improved images. It can also rapidly fill organs with fluid, allowing endoscopic ultrasound. For optimal performance of your OFP-2 pump, use the MAJ-1651 and MAJ-1652 disposable tubing.
FORUMSView All (4)
2Replies3 days ago | Irrigation Pump stops by itself The pump stops running and to restart release foot switch & press again. Does anyone give some advice please? Mycha appreciated your help. Thanks you Reply |
2Replies7 months ago | OFP-2 FLUSHING PUMP Maintenance and Repair Manual Hi, Im looking for the Maintenance and Repair Manual for the Olympus Flushing Pump OFP-2. Can someone please help? Equipment: OFP-2 FLUSHING PUMP Reply |
0Replies2 years ago | NO FLOW DOES ANYONE HAVE ACCESS TO THE OFP-2 SERVICE MANUAL. i NEED TO DIAGNOSE WHY THERE IS NO WATER FLOW FROM THE UNIT. PUMP APPEARS TO BE OPERATING PROPERLY WITH WHEEL SEEN TURNING FROM UNDERNEATH. ARROWS TO CONTROL THE FLOW ARE NOT WORKING AND THE LED STAYS IN THE INITIAL POSITION (ONE LIGHT ON)Reply |
- Irrigation via the instrument or water channel: The OFP-2 can irrigate fluid via the instrument or auxiliary water channels of endoscopes, allowing gastric and colonic mucosa to be washed during procedures.
- Powerful and controlled flow rate: A powerful flow allows organic material to be washed away efficiently while precise microprocessor controls prevent over-pressurization of endoscopes.
- Rapid fluid filling for EUS: The OFP-2 is able to rapidly fill organs with fluid, allowing endoscopic ultrasound procedures to be performed.
- Remote control or footswitch operation: The OFP-2 can be controlled via a remote control or a footswitch, allowing the user to choose the method that suits the procedure best.
