Olympus - MU-1
The MU-1 Maintenance Unit allows for proper care and maintenance of Olympus endoscopes.
0Replies6 months ago | Olympus MU-1 - breaker part Does anyone have the actual mfr part number or the specs on the circuit breakers themselves? Reply |
0Repliesa year ago | This unit is titled as a "Light source".. LOL This is not a light source. This is an air pump to pump air through an endoscope to find leaks.. Somehow it has been labeled as a light source for some reason.. I guess it looks like one a little on first view..Reply |
- Compatible with all OES fiberscopes and EVIS EXERA videoscopes.
- Alcohol flushing of the air/water channel (compatible with OES fiberscopes and 100/130/200/230 series scopes).
- Power Supply Voltage: 120 V, 220 to 240 V.
- Size:
- Dimensions: 85 mm (W) x 157 mm (H) x 170 mm (D).
- Weight: 4 lb (1.8 kg).
- Operating Environment:
- Ambient Temperature: 50 to 104 degrees Fahrenheit (10 to 40 degrees Celsius).
- Relative Humidity: 30 - 85 %.
- Air Pressure: 700 to 1050 hPa.
