Invacare - Check O2 Plus
Oxygen Monitor
Designed with technicians in mind. Measure oxygen purity, flow rate and outlet pressure all in one, simple, two-button device without the need for in-field calibration. Three measurements rolled into one oxygen analyzer for ultimate convenience.
2Replies4 years ago | Calibration I have an Invacare IRC 400 Check O2 Plus that is reading off on the flows. No longer supported. When I opened the case, there are jumper blocks for Gain, Offset, Power, and Function. I am wondering if anyone out there knows if it's possible to utilize these to calibrate the flow on this device and has instructions for doing so. Thanks! Reply |
- Automatic shut-off extends battery life
- Two AA batteries provide over 16,000 readings
- Includes connection tube
- Protective boot helps increase product integrity
