Alma Lasers - Quantel EXEL02 CO2
by Alma Lasers
Fractional Laser
If you are looking to rejuvenate your skin then The Beverly Hills Rejuvenation Center has just the thing to give your skin the glow you dream of! Other fractional lasers don’t hold a flame to the Quantel EXEL O2, the perfect solution to the wrinkles, dark marks and damaged skin preventing you from the look you’ve always desired.
The Quantel EXEL O2 utilizes fractioned lasers to resurface your skin, stimulating natural collagen production and ultimately inspiring your body to return that youthful brightness to your skin. Fractional laser resurfacing targets only the small areas that require resurfacing, so only the skin that you wish to improve needs to be treated. The Quantel EXEL O‚ offers a 4 cm2 of treatment area at a time, meaning the process takes less time to complete than other approaches to the same procedure. With Quantel EXEL O2 you can have a large area treated quickly and effectively.
The micro-fine ablation zones and intense thermal stimulation of the Quantel EXEL O2 encourages skin renewal and collagen synthesis unlike any other procedure. The fractional laser treatment will target your wrinkles, scars, and pigment changes for optimal results. The specific patterns of the treatment are not visible after treatment, which means no one will be able to tell that you had any work done. All you’ll have to show you had this fractional laser treatment done is a natural and improved appearance.
First, we digitally evaluate your skin to inspect the area you wish the procedure to cover, as well as the level of damage done to that area. Then the process begins! Because the Quantel EXEL O2 has such a large treatment area, we can complete the whole face in less than an hour so you can go back to living your life with the collagen boosted face you’ve always wanted.
The best part of the Quantel EXEL O2 fractional laser treatment is the cold air cooling system attached to the scanner. The cold air cooling makes it possible to have a comfortable skin resurfacing treatment that won’t require anesthesia and excessive numbing creams. The cooling system also reduces the chances of uncomfortable side effects post-procedure.
So what are you waiting for? Don’t let age have the last word! Come to The Beverly Hills Rejuvenation Center to take care of those scars, wrinkles and dark spots plaguing your face. The Quantel EXEL O2 offers the best rejuvenation results by fractional laser treatment, and The Beverly Hills Rejuvenation Center offers the best customer service and care.
Achieving a youthful glow has never been this easy!
0RepliesSun Apr 02 2023 | Error 567 What does the error 567 mean,. Can i have operation manual Equipment: Alma Lasers - Quantel EXEL02 CO2 Reply |
1ReplyTue Sep 08 2020 | Service Manual Hello. I am trying to locate a service manual for the Exelo2 CO2. Not the operational manual, but the actual Service manual for repairs. Can someone help me out?Reply |
0RepliesFri Jan 24 2020 | Alma Lasers EXELO2 EXELO2 - The fractional CO2 laser systemReply |
