Karl Storz - Endomat Select
ENDOMA ®SELECT for arthroscopy is a roller pump that regulates the irrigation of fluids according to the latest standards.
ENDOMAT®SELECT for arthroscopy communicates effectively with the KARL STORZ shaver unit UNIDRIVE® S III ARTHRO. It also regulates the pressure and the flow rate to provide optimal imaging while maintaining joint distension. An optional feature is the BOOST mode that can be activated at any time. This provides a temporary increase in pressure and irrigation inside the joint in order to stop bleeding.ENDOMAT® SELECT has been designed as an interdisciplinary pump. Depending on individual preferences, the pump can be equipped with various software packages so that the unit can be used for either individual or multiple disciplines.
0Replies4 years ago | Pump tubing not loading Karl Storz ortho pump hamou endomat 26331020 Need a copy of the service manual or any repair info Reply |
- User-friendly interface and simple handling thanks to tubing set for single hand control
- Rapid communication with the shaver unit
- Safe use thanks to tubing set recognition
- Seamless integration into existing systems
- Optional software allows further applications to be added at any time
- License, allows selection of the procedures "knee," "hip,' "shoulder" and "small joints," for use the ENDOMAT®SELECT UP 210
- Tubing Set- irrigation, PC, for single use, sterile, package of 10, for use with KARL STORZ HAMOU® ENDOMAT®263311 20 and ENDOMAT®SELECT UP 210
- for transmission of the footswitch signal between UNIDRIVE® S III ARTHRO SCB 28 723020-1 and ENDOMAT®SELECT UP 210
