Philips - HD 7
by Philips
Ultrasound System
A system that takes advantage of proven, reliable system architecture, software and transducers to deliver high performance for the office-based cardiologist. Engineered and built for high volume use and day after day reliability the HD7 has been designed for user simplicity, easy learning and quick adoption even by clinicians with limited ultrasound experience. The HD7 ultrasound system is a mobile, midrange color and grayscale ultrasound scanner.
4RepliesTue Apr 28 2026 | D7 XE – STOP c0000218 Registry File Failure – looking for disk image Hi all, I have a Philips HD7 XE ultrasound system with the following specs:
The system fails to boot with BSOD: Disk (Seagate Barracuda ST3250310AS) has been tested — SMART passed, extended self-test passed, no bad sectors, no I/O errors. The issue is purely the SOFTWARE registry hive content. Attempted: ntfsfix (filesystem was unclean, now fixed), chntpw inspection (hive partially navigable but corrupt), truncating SOFTWARE.LOG. No restore points, no repair folder on this XP Embedded installation. I need either:
Philips support confirmed they cannot assist — system is out of support. Any help appreciated. Equipment: Philips HD7 Reply |
2RepliesMon Oct 31 2022 | BIOS PASSWORD Hello sir, Did you can help me with bios password,Reply |
2RepliesWed Oct 27 2021 | Don't boot-up anymore How can I get into the bios (Ctrl-S?) to set the hard disk as the 1st boot disk? With ctrl-s I get into the bios but I can't set up harddisk/cd/floppy or anything, indicates that no other settings are possible. Has stood still for a while and starts now suddenly no longer on, possibly back-up battery on the motherboard empty causing the setting to be changed? Who can help me?Reply |
Applications
| Cart Based | 1 |
| Clinical Applications | Colorectal |
