Bio-Med Devices - Bio - Med Devices 2004
The 2004 is a High-Low Flow Blender (with the emphasis on High).
It has 3 DISS ports (left, right and bottom). If anything is screwed onto the right side port, the 12lpm bleed flow is activated and the blender's accuracy range is from 2-108 lpm. This bleed flow will be active whenever the blender is connected to an air and oxygen gas source (even if the flow meters are turned off). If nothing is connected to the right side port (the bleed is not active), the accuracy range of the blender is between 15-120lpm.
