Joerns - Hoyer Stature
Vertical lift.
The Hoyer® Stature® combines the benefits of Vertical Lifting and "Clip" style slings. With a 500 lb. Safe Working Load and one of the largest lifting ranges available, the Stature is able to cope with even the most demanding and technical of resident handling situations. The Stature can lift residents from the floor as well as accommodate transfers to higher surfaces, while allowing the choice of different sling systems.
0Replies8 months ago | hanger bars Hello- I'm trying to find out how to change out hanger bars. I joined to download your pdf of the manual. Thank you, Becky Equipment: Joerns - Hoyer Stature Reply |
- True vertical lifting
- Clip style positioning cradle
- Optional powered cradle
- Swan neck style legs
