Abbott - FreeStyle Lite
FreeStyle Light has been designed to make busy lives easier.The meter is easy to learn, easy to use, the display is easy to read, and the test is fast and accurate. With the world's smallest blood sample size1, this meter allows for virtually pain free testing! FreeStyle Lite is the latest addition to the Abbott Diabetes Care range of blood glucose monitors.FreeStyle Lite eliminates the need to code your meter with every new pack of test strips making testing easy. You simply open the packet of strips, test and get on with life.
4Replies12 years ago | do not take measurement When i set the strip into the apparatus, it lights up and asks for the blood droplet. But when i apply the droplet, a rectangle flashes at the top of the window and the thing turns off. What would be the problem? Reply |
[list] [*] No coding required to make testing easy [*] World's smallest blood sample size to help make testing less painful [*] Fast 5 second average test time [*] Large 400 result memory to help manage diabetes [*] Large numeric display is easy to read [*] Can be used on alternative test sites other than fingertips [*] Download results to your PC using [u]Co-Pilot[/u] or [u]Precision Link[/u] [*] Backlit display and port light to make testing [*] Backlit display and port light to make testing in low light easy [*] Programmable alarms to remind you to test [*] Strips in a convenient canister [/list]
Height | 7.4 cm |
Length | 1.7 cm |
Weight | 34.7 g |
Width | 4 cm |
Memory: 400 blood glucose and control solution tests with date and time Sample Size: 0.3 microlitre (300 nanolitres) Test Time: Average of 5 seconds
