Chattanooga - Hydrocollator M-4
Heating unit
0Replies2 years ago | Drain valve leak for M-2 There is a leak at drain valve tip where it connects to the hose. How can I repair it or steps to replace with a new drain valve. It is very tight to loosen the valve from the tank, any idea what needs to be done.Reply |
3Replies3 years ago | WIRING DIAGRAM Could someone please tell me where to find a wiring diagram for this unitReply |
- High-quality stainless steel
- Thermostatically controlled temperature
- 3" (8 cm) swivel-type rubber casters for silent, friction-free movement
- Easy maintenance. Simple to fill and drain. No plumbing required: uses 110 current, 12.5 amp
- One-year warranty
- Full fiberglass insulation on mobile units to ensure minimum energy use and prevent heat loss
- Requires just 20" by 32" floor space
- Extra large tank
- Oversized drain
- Inside racks
- A second thermostat guards against low water level and overheating
