Shimadzu - SDU-1200 Pro
by Shimadzu
Special-purpose system with applications in abdominal, pelvic, fetal, urologic, and vascular imaging.
FORUMSView All (5)
-Jeff Alexander
Tue Sep 17 2013
looking for probe select board
part number 541-50133-03
-ahmadayyoob
Tue Jun 05 2012
windows nt to lood
Some files are lost, and I have a problem in windows nt. Can anyone help?
-tahoegal61
Mon Apr 02 2012
Shimadzu SDU 1200 User's Guide/Owner's Manual
Looking for User's Guide for Shimadzu SDU 1200. Any ideas?
Micro Imaging Array Technology Provides Ultra-High-Definition Images
  • Delivers the highest level of spatial resolution available via our unique Micro Imaging Array technology. It realizes high frequencies and wide aperture imaging at up to15 MHz to expand the boundaries of ultrasound diagnosis.
Advanced Digital Technology Delivers High Image Quality
  • The Pro is equipped with a digital beam former that uses advanced digital technology to deliver higher-quality ultrasound images. The SDU-1200Pro full-digital color diagnostic ultrasound system faithfully records a large amount of diagnostic information and provides the high frame rates, accurate focus, wide dynamic range, and high frequencies demanded for ultrasound diagnosis.
True Motion Imaging Captures Transitory Movement
  • The SDU-1200Pro's high frame rate captures even momentary movement during examinations. True Motion Image provides high temporal resolution for greater diagnostic confidence.
ASI Displays an Optimized Image at the Touch of a Single Key
  • Commonly used parameters can be stored in the ASI (Application Specific Imaging) key. Even in CFM mode that requires complex parameter settings, a single key touch displays images using previously-registered image parameters. Shimadzu's SDU-1200Pro lets anyone easily register the image parameters needed for their own clinical applications.
Cart Based1
Weight308 lbs
Clinical ApplicationsColorectal
Color-flow Mapping1
Doppler ModesColor, Pulsed wave (PW), 3-D
Image Display15 in Color CRT
