Abbott - FreeStyle Freedom Lite
With a new ergonomic shape and large numeric display, the FreeStyle Freedom Lite is ideal for those looking for simple and accurate testing.Introducing the easy-to-read, easy-to-hold FreeStyle Freedom® Lite blood glucose monitoring system. With a new ergonomic shape and large numeric display, the FreeStyle Freedom Lite is ideal for those looking for simple and accurate testing. Also, no coding and the world's smallest sample size means easy testing on the go. The FreeStyle Freedom Lite meter uses only FreeStyle Lite test strips.
1Reply13 years ago | Freedom Lite Readout Is the READOUT of the Freestyle Freedom Lite in whole blood or plasma?Reply |
[list] [*] No coding required [*] FreeStyle Lite test strip that is compatible with the FreeStyle Lite and FreeStyle Freedom Lite meter [*] Large reading in a small, discreet meter [*] 7-, 14- and 30-day averages with 400 results in meter memory [*] Yellow strip port so patients can readily see where to insert the test strip [/list]
Height | 3.3 in |
Length | 0.63 in |
Weight | 1.5 oz |
Width | 2 in |
[list] Sample Size: 0.3 microliter (300 nanoliters) Test Time: Average of 5 seconds [/list]
