Ampronix - Chromamaxx 15CDYS2
by Ampronix
Display monitor
The Chromamaxx 15CDYS2 is a replacement for existing CRTs currently being used with the Solar 8000, bringing the popular patient monitor device to the digital format. The 15CDYS2 comes assembled with a stand that is mountable to the Solar 8000. The LCD's base easily installs into the existing Solar 8000 mounting configuration. The Chromamaxx 15CDYS2 is the LCD solution with the required parameters for compatibility with the Solar 8000 patient monitor system. The 15" LCD has a fast refresh rate and ensures that patient monitoring will be bright, sharp, and easy-to-read.
  • Diagonal 15 Inch TFT active matrix panel
  • Response time 16 ms
  • Contrast ratio 500:1 (typical)
  • Viewing zone H: 150°, V: 125°
  • Resolution 1024 x 768
