Abbott - FreeStyle Freedom
The FreeStyle Freedom glucose meter manufactured by Abbott Diabetes Care promotes ease of reading and ease of handling components.The FreeStyle Freedom glucose meter manufactured by Abbott Diabetes Care promotes ease of reading and ease of handling components. This glucose meter is made by a well-known name in the diabetes care field and has many wonderful components which are designed to make procuring blood glucose level results easy as can be. The following will describe some of the product characteristics along with some pros and cons which may go along with the use of the FreeStyle Freedom glucose meter. The FreeStyle Freedom glucose meter is a glucose monitoring system which has many favorable attributes. This particular meter has an easy to read display screen, ergonomic design for easy handling, 5-second test results, ability to reapply the blood sample within one minute of previous testing and programmable alarms. In addition, this glucose meter allows for alternate testing sites which enable the individual to use sites other than their finger for constant testing. The FreeStyle Freedom stores up to 250 prior test results and has an automatic shut off component which will aid in saving battery life should one forget to shut down their glucose meter after testing. It also requires an extremely small sample size of 0.3 microliters which makes for less painful and less prolonged testing. If you are looking for an above average glucose meter with more than enough functions, quick testing time, good memory capacity and easy handling components, then the FreeStyle Freedom is the way to go. The inexpensive price tag is another reason to buy this model as you really get a lot for your money. For those who may need a bit more functions and greater memory capacity, there are other models available on the consumer market which might be more suitable. With that said, the FreeStyle Freedom is certainly not lacking in many areas.
1Reply10 years ago | error CODE 49 Hi, I would like to know why everytime I insert a test strip on the model CAGK 159-B2832 I get a CODE 49?
Thank you in advance atv Reply |
0Replies12 years ago | Adquirir Equipo Perdi el equipo y necesito otro para poder utilizar las tirillas que tengo, ya que son una cantidad considerable y el equipo no lo he podido encontrar en Puerto Rico. Y llevo bastante meses buscandolo. Reply |
[list] [*] Quick test results which users can achieve by using this type of glucose monitoring system [*] 5-second test results [*] Stores up to 250 test results [/list]
