GE HealthCare - S/5 AM
by GE HealthCare
Complete monitoring for anesthesia
The S/5 Anesthesia Monitor (AM) is a multiparameter monitor that offers a flexible and upgradeable solution for routine to the most demanding anesthesia applications. From a wide selection of parameter modules, you can choose the set of parameters that best suit your specific needs today. And when your needs evolve, the modularity of the S/5 AM allows you to expand the capabilities of your monitor to meet your new needs.          The S/5 Anesthesia Monitor combines comprehensive hemodynamic and cardiac monitoring with bedside arrhythmia detection, full respiratory and ventilatory monitoring and continuous, automatic assessment of neuromuscular blockage level. In addition, it uniquely integrates neurophysiological monitoring, continuous gas exchange and metabolics, and automated tonometry to help provide you with a comprehensive picture of patient status.          The variety of display options, extension frames and command boards offers flexibility by allowing the workplace to be customized to your needs. The intuitive user interface, common with the other S/5 products, anesthesia dedicated keyboard and module direct keys helps make the S/5 AM easy to learn and easy to use, freeing your time for patient care.           Together with the S/5 Anesthesia Delivery Unit and deioRecorder, S/5 Anesthesia Monitor forms a comprehensive, integrated and ergonomic system helping to provide real value for patient care. Connecting S/5 AM to S/5 Network and Central Monitor makes historical monitoring data available from the remote location, even from your office PC.
-SteveG
Fri Sep 19 2014
NIBP Module
I am having trouble tracing a leak within the M-NESTPR module.
anyone seen this before?
[list]    [*] Flexible, extendable monitor for use in routine anesthesia to demanding applications.      [*] Combines hemodynamic and cardiac monitoring, neurophysiological monitoring, full respiratory monitoring and continuous automatic assessment of level of neuromuscular block.      [*] Modular design allows you to configure your anesthesia workstation to your own space and patient requirements.      [*] Provides a wide range of parameter modules, display options, workspace options and anesthesia documentation tools.      [*] Acclaimed ease-of-use: anesthesia care oriented intuitive user interface; logical, easy to navigate menu structure; and short-cut keys for easy and rapid access to the most common monitor functions.      [*] Together with the S/5 Anesthesia Delivery Unit forms a truly integrated and ergonomic workstation.    [/list]
Height265 mm
Length 68 mm
Weight2.75 kg
Width315 mm
Display size 12.1 in diagonal     Display type: Active matrix color TFT LCD     Display resolution: SVGA, 800x600     Mounting: Can be mounted to desk stand, wall, or to various anesthesia machines
