CS Medical - TEEClean Automated TEE Probe Cleaner Disinfector
by CS Medical
Washer/Decontaminator
Designed exclusively for transesophageal echocardiogram ultrasound probes (TEE), TEEClean provides both manufacturers recommended cleaning and high-level disinfection of soiled TEE probes in the same device. TEEClean Automated TEE Probe Cleaner Disinfector is the first product of its kind to be cleared by the US FDA. TEEClean allows the healthcare professional to simply place a bedside cleaned TEE probe into the device, removing the potential of an ineffectively cleaned TEE probe being high-level disinfected.
2RepliesFri Apr 22 2022 | Failed Filter Change Cycle Good Afternoon Biomeds, I was called for our TEE Clean failing the cycle during the air filter change. The temperature switches were tripped which I corrected. Tech support recommended leaving the shunt in place and entering the info off of the new filter to prevent wasting a filter. As it was running the 5 rinse cycles, it made it through the 4, then on the 5th, it would fill the reservoir and then the water would not circulate (with the pump running) nor drain. Tech support wants me to send it in for repair and I would like to avoid doing that. Does anybody have any other useful troubleshooting advice or a service manual which would help with troubleshooting this device? Thank you in advance for any help.Reply |
0RepliesFri Mar 06 2020 | TEEClean® Automated TEE Probe Cleaner Disinfector TEEClean Automated TEE Probe Cleaner Disinfector is the first product of its kind to be cleared by the US FDA. Designed exclusively for transesophageal echocardiogram ultrasound probes (TEE), TEEClean provides both manufacturers recommended cleaning and high-level disinfection of soiled TEE probes in the same device.Reply |
