Datascope ACCUTORR 3/4 BP Montior and Pulse Oximeter
The Datascope ACCUTORR 3/4 uses the oscillometric technique to rapidly and
accurately measure non-invasive blood pressure (NIBP), heart rate, and with the
ACCUTORR 3 SAT and ACCUTORR 4 SAT models, oxygen saturation (Sa02).
- The monitor features large, front panel digital readouts; manually-initiated or automatic NIBP measurement cycles; and an integral liquid crystal display (LCD) for the presen tation of trended data, advisory messages, alarm conditions, elapsed time, a 24-hour clock, and when available a Sa02 waveform. The automatic NIBP measurement cycle uses a continuous timer, permitting automat ic sequential measurements of NIBP. These NIBP measurements, along with heart rate and Sa02 measurements, can be displayed on the LCD as trended data in either a list or graphic format.
- The LCD also displays advisory messages indicating correct or incorrect monitor /«*% operation, and when necessary, the LCD will also display messages during a measure- / ment cycle or display messages to qualify a completed measurement cycle. The Datascope ACCUTORR 3/4 allows you to select audible and visual alarm limits. All alarm violations are indicated by an audible alarm tone and flashing front panel dis plays. The monitor is available in four configurations. The basic model, the Datascope ACCUTORR 4, is configured for NIBP and heart rate.The Datascope ACCUTORR 4 SAT adds Sa02.
- The Datascope ACCUTORR 3 is equipped with a recorderfor documenting NIBP and heart rate information. Use the Datascope ACCUTORR 3 SAT if a printout of NIBP, heart rate, and Sa02 is desired. Each printout includes the time and date of each measurement taken and when displayed, patient advisory messages. All four configurations feature battery operation and User-Configuration . When the unit is not in the process of performing an NIBP measurement it continuous ly recalibrates to zero pressure, updating the offset pressure once every second.
Width:1.33 (in)Height:2.52 (in)Depth:7.01 (in)
