Nova Metrix - 512
by Nova Metrix
Pulse Oximeter
The 512 is a lightweight, easy to use, handheld pulse oximeter perfect for Veterinarians. The 512 provides reliable continuous measurement and display of the oxygen saturation of arterial blood (SpO2) and pulse rate. In addition, it utilizes Novametrix' patented "digital" technology providing the same improved performance in conditions of motion artifact or low perfusion as found in their full featured pulse oximeters. Features an easy to read LED display with a pulse activity bar to verify signal quality and aid in sensor placement. Includes a Y-site probe. Operates from 2 AA batteries and weighs less than 6 ounces.
SERVICE COMPANIESView All Pulse Oximeter Companies
  • The Respironics/Novametrix Models 512 and 513 handheld pulse oximeters incorporate “digital” signal processing.
  • This advanced technology is able to process pulsatile signals at much higher resolutions and speeds of 100 times per second.
  • This processing technique results in improved pulse oximeter performance during motion or low perfusion, where traditional handheld monitors fail.
  • Designed for easy portability
  • Versatile for all monitoring situations
  • Operates from 2 alkaline batteries or an optional DC supply
  • Equipped with a "Y" sensor that is designed for durability
  • The 513 provides an infrared output allowing trend information to be sent to a printer or downloaded
  • Alerts: Automatic and adjustable SpO2 and pulse rate limits
  • Pulse Beep: User selectable on/off
  • Communications: 513 - Infrared link allows downloading of up to 24 hours of patient data to a computer or printer
  • Principle of Operation: Red/Infrared absorption
  • Pulse Rate:
    • Range: 30-250 bpm
    • Accuracy: 2 bpm
    • Resolution: 1 bpm
    • Averaging: 8 seconds
  • SpO2 (Oxygen Saturation):
    • Range: 0-100%
    • Accuracy: 80-100% 2% SpO2 ; 1 standard deviation ; 0-79% unspecified
    • Resolution: 1%
  • General:
    • Size: 4.25"H x 2.25"W x 1.0"D | 10.8 x 5.72 x 2.54 cm
    • Weight: 5.7 ounces | 162 grams (Including batteries)
    • Display: Numeric 7 segment LEDs, LED Pulse Bar Graph proportional to signal strength
    • Electrical: Batter: 2 AA alkaline, 16 hour life
    • Auto Shut Off: Monitor automaticaly shuts itself off after 3.5 minutes if no data is being received
    • Low Battery Indicator: Illuminates when approximately 30 minutes of battery life remain
    • Monitor Status Messages: Error code displayed for various monitoring related conditions
