Soering - MBC 600
by Soering
Great safety with traffic-light alarm system. The MBC-600 represents monopolar cutting and coagulation and bipolar coagulation.
The Traffic-light alarm system continually monitors the placement of the Patient Electrode and its contact to the patient. Visual and audio alarms alert the user to wrongly connected, misplaced or damaged patient-electrodes, and then the system switches off automatically before critical parameters are reached.      In unlikely event that preset parameters are not attained the function error warning will illuminate, an audio alarm sound and the equipment automatically shuts down. An error code will display to facilitate fault tracing.      [b]Monopolar cutting [/b]  MBC units automatically select the optimum cutting intensity.      [b]TUR:[/b] Achieves excellent results in fatty tissue or under water cut, such as in Trans-Urethral Resection and Histero Resection.      [b]Blend:[/b] This mode allows cutting and simultaneous coagulation of the raw surface. There are 9 degrees of coagulation ranging from light to strong.      [b]Pulse:[/b] In this mode a pulsed current greatly enhances safety when cutting in visually obscured areas, as in Polypectomy or similar procedures.
[list]  [*] Easy to handle    [*] Automatic arcbow control cutting system    [*] Great safety with traffic-light alarm system (automatic check of the patient electrodes)    [*] Possibility to pulse the cutting current as it is used in Polypectomy or similar procedures    [*] Excellent results in fatty tissue or under water cut    [*] 10 individually programmable storages    [*] The MBC-600 represents monopolar cutting and coagulation and bipolar coagulation  [/list]
Height5.9 in
Length 16.6 in
Weight37.4 lbs
OutPut Frequency350 kHz
Output Power350 W
Width16.9 in
