ARKRAY USA - Assure 3
by ARKRAY USA
The Assure® 3 Blood Glucose Monitoring System makes testing 3 times faster. And, the Assure 3 uses state-of-the-art biosensor technology.
The Assure® 3 Blood Glucose Monitoring System makes testing 3 times faster. And, the Assure 3 uses state-of-the-art biosensor technology. Calibration is easy - simply insert the code chip and the meter is ready to test. To test, simply insert a test strip and the meter turns on. Apply sample and obtain plasma-referenced result in only 10 seconds. Assure 3 uses a specially designed Guide-Me Curve test strip for ease of handling.
  • 3 times faster test time - 10 seconds from sample application to result
  • Smaller sample - uses only 3 µL blood sample
  • Automatic On/Off with insertion and removal of test strip
  • Code Chip Calibration
  • Wide Test Range 30-550 mg/dL
  • Plasma-Referenced Results
  • Biosensor technology - virtually no cleaning required
  • Designed for easy testing in the palm of your hand or solid enough for easy table top testing
  • Capillary action quickly wicks the sample into the test chamber
  • Clear view of sample chamber ensures accurate results
