BioSense - Recirculator II
Air purification system.
The Recirculator II air purification system can convert standard patient rooms into CDC compliant negative pressure or positive pressure Protective Environments (PE) and Airborne Infectious Isolation Rooms (AIIR) at a fraction of the cost of traditional methods. Having the flexibility to relocate the Recirculator II to another room quickly, adding isolation wards or patient isolation surge capacity to new or existing facilities easily.
- Portable
- Output: 575 CFM
- Air changes per hour 13’ x 15’ 8’ room: Approximately 22
- Noise level: 53 dB
- Performance monitoring: Minihelic gauge
- Exhaust: Recirculate & negative pressure Both
- Exhaust duct: size 8” diameter
- 97% effective HEPA
Height | 39 in |
Length | 13 in |
Weight | 55 |
Width | 19 in |
