Fanem - FOG 2140A
Heated humidifier.
After setting the temperature, the respiratory Humidifier automatically maintains the temperature of the inspiratory gas administered to the patient. It can be used together with a mechanical ventilator, bubble CPAP, associated with high flow therapy, or even with a resuscitation device for neonatal, pediatric and adult patients. Its color display presents essential information for supplying patients with the best therapy. The Humidifier has excellent performance, permits use of a heated circuit and is also equipped with an overheating prevention system, in order not to compromise patient treatment or impair equipment performance.
- Microprocessor-based controls
- Adjusts temperature administered to patients (servo control)
- Indicates temperatures at the chamber outlet and close to the patient, as well as humidity supplied to the patient, date and time and length of use by the patient
- Audible and visual alarms
- Key for selecting mode of use: Invasive or Noninvasive
- Key for silencing alarms
- Enables circuit with heating
- Double sensor for monitoring temperatures close to the patient and at the water chamber outlet
- LCD color screen
- Invasive and Noninvasive mode
- Compatible for use with mechanical ventilators
