Fanem - FOG 2140
Heated humidifier.
The FOG 2140 is an adjustable Humidifier designed for use with mechanical ventilators, neonatal bubble CPAP or resuscitation devices. It operates through a humidification chamber installed in the Humidifier and the gas transported within the respiratory systems that will be heated, humidified and delivered to patients. It can be used for neonatology and pediatrics, as well as for therapies with adult patients. The temperature delivered to the patient can be set through defining the temperature of the heating plate, thereby automatically and continuously maintaining the supply of temperature to the patient; The equipment was designed with excellent safety features, which makes it possible to avoid overheating, in order not to compromise patient treatment or impair equipment performance.
- Microprocessor-based controls
- LED display
- Indicates temperatures of the heat plate, chamber outlet and close to the patient
- Audible and visual alarms
- Indicates when equipment is on and heating
- Double sensor for monitoring temperatures close to the patient and at the water chamber outlet
- Compatible for use with mechanical ventilators.
