Vitalograph - ALPHA
by Vitalograph
The World's Easiest To Use Spirometer
he Vitalograph ALPHA™ is the spirometer of choice for respiratory care professionals around the world due to its ease of use, portability, integral printer and long term reliability.
The precise and durable measurement technology is extremely accurate and stable over time, assured through our simple calibration check routines as recommended by international spirometry guidelines (ARTP, ATS/ERS, etc.) and good practice. No need for expensive disposable sensors, turbine, spirettes nor flow tubes with optimal hygiene assured via Vitalograph Bacterial Viral Filters (BVF™).
Simply enter the patient’s age, height and gender, select the required test type and begin testing. The Alpha automatically determines the best test and shows simple and clear real-time graphs, interpretation and test quality control information. When testing is complete you can print the report directly from the built-in thermal printer – no PC is required.
The ALPHA is supplied with Vitalograph Reports Software with the ability to create editable PDFs for filing and manual upload to electronic medical record (EMR) systems. Suitable for adult and paediatric patients, and with new GLI spirometry predicted equations and Z-Scores included as standard, the ALPHA is suitable for general healthcare and occupational health environments.
Product | Vitalograph ALPHA |
Model Number | 6000 |
Size | 300 x 250 x 75mm |
Weight | 2kg net |
Parameters | Varies by country variant |
Operating Temperature Range | ATS Limits: 17-37°C Design Limits: 10 - 40°C |
Voltage/Frequency | 110 - 250V~50/60Hz |
Flow Detection Principle | Fleisch type pneumotachograph |
Volume Detection | Flow Integration sampling @ 100Hz |
Accuracy when in Operating Range | Flow +/- from 10% to 5% Max flow rate +/-16L/s Min flow rate +/-0.02L/s |
Volume Accuracy | Better than +/-3% |
Maximum Displayed Volume | 10L |
Maximum Test Duration | 90 seconds |
Flow Impedance | 0.1kpa L/s @ 14L/s Complies with ATS/ERS 2005 |
Printer | Thermal |
Performance Standards | ATS/ERS 2005 ISO 26782:2009 ISO 23747:2007 |
Safety Standards | IEC 60601-1:2005 |
Medical Safety Standard | Medical Devices Directive 93/42/EEC as amended |
Designed & Manufactured Under | ISO 13485:2003 and 2016 FDA 21 CFR 820 CMDR |
Communications | USB and Compact Flash |
