Stryker - XPRT Mattress
Therapy mattress
The XPRT Therapy Mattress is a powered mattress replacement system intended only for use on Stryker frames and other frames supporting a 35 x 84 inch litter format in the Critical Care environment. It provides low air loss, pressure redistribution, percussion, vibration and rotation therapies and additional nursing convenience features. The unit consists of a sleep surface, an integrated valve box located in the head of the mattress, a pump box located under the foot of the mattress and a color touch screen controller that can be mounted to either side of the pump box or integrated into the footboard depending on the model.
1Reply4 years ago | Stryker InTouch XPRT mattress works for several minutes then stop operating, Serv. Req. By Qual. Pers. appears. XPRT mattress works for several minutes then stops operating, then Serv. Req. By Qual. Pers. appears on footboard display under Bed Surface tab. I have changed the XPRT Pulmonary mattress and then XPRT control box and then the short gray cable from bed frame to control box, still getting message: Alarm Service Required By Qualified Personnel. I can reset error by unplugging XPRT Control Box, then it operates several minutes and message reappers. Reply |
- Rotation featuring >80 degress total arc (for patients with shoulder width of 18 inches or less)
- Low air-loss
- Rotation with fowler at 45°
- Turn assist hold capability
- Adjustable percussion BPS, intensity and duration
- Adjustable vibration intensity and duration
- Percussion/vibration (right lung, left lung or bilateral)
- Dartex® cover
- Two layers of pressure-relieving surface
- Heel-specific ulcer prevention/treatment
- Maximum inflate
