Medison - SONOACE 9900
by Medison
The SONOACE 9900 offers full range of applications specially designed for user's practice.
Providing crystal-clear B/W and color images with a higher frame rate and versatile new applications based on full range of 3D functions, the SONOACE 9900 demonstrates the values of the future of the ultrasound technology.
FORUMSView All (19)
-ismaeel09
Sun Aug 28 2022
Power problem
The ultrasound is connected to the mains and switched on the right side switch (ON / OFF). The device illuminates the control buttons and immediately turns off. What solution do you recommend? thanks
Equipment: Medison - SONOACE 9900
-ERVet
Sat Apr 17 2021
Start-up - system is not loading on the screen
Hello, I need a advice what can be possible sollution: - I'm starting the system - i can hear that its started - fan are working - there is no signal on the screen - tried other screen, socket no response if you know what could be the issue here and possible solution thank youReply
-ammar0077
Sun Sep 29 2019
I am very sad
no one anser me for cod erro SA9900 the cod is 29 and 0 Reply
  • High Resolution 17" LCD monitor
  • Speckle Reduction Filter
  • Full Spectrum Imaging
  • High Sensitivity Powerful Doppler Performance
  • Dual Live Mode
  • Built in DVD RW
  • Optimized parameters for 2D, 3D, 4D and Doppler
  • Innovative design with optimum use of space
Cart Based1
Clinical ApplicationsColorectal
Imaging Capabilities2D/3D/4D
Image Display17 in
