LifeScan - OneTouch Ping
OneTouch Ping is the intelligent glucose management system with one thing on its mind: working together to help you perform at your best.Like other insulin pump systems, OneTouch Ping frees you from multiple daily injections and gives you the ability to quickly and easily adjust your insulin based on your body’s immediate needs. But unlike other systems, OneTouch Ping delivers the double whammy in terms of smarts. The pump is packed with unique capabilities that may be accessed both wirelessly (by using the meter-remote) and manually. And the meter-remote, with its full set of functions, is designed to make your life with diabetes easier and more discreet. In fact, you can even dose your insulin from it.
0Replies5 years ago | Checklist Where do I get the routine inspection checklist for glucose monitor ? Reply |
- It matches your body's needs like no other pump system.
- OneTouch Ping gives you the smallest basal increment available (0.025 U/hr) for more precise basal dosing
- The meter-remote can store the nutritional values of 500 of your favorite foods, via CalorieKing®, for easy and accurate carb counting on the go. Using ezManager® Max software, you can even customize the database or enter your own favorites (like Mom’s chicken soup).
- It's got beauty as well as brains. - The OneTouch Ping insulin pump has a flat panel color screen that uses the same screen technology as the latest televisions and digital cameras.
- Proven Waterproof. - The OneTouch Ping insulin pump is proven waterproof up to 12 feet for 24 hours so you can jump in the pool or get caught in the rain without worry.
Operating Range Minimum: 3.3 feet (1 meter) obstructed
Minimum: 9.8 feet (3 meters) unobstructed
Communication Time Minimum: 0.5 seconds (approximately)
Maximum: 10.5 seconds (approximately)
Frequency Range: 902–928 MHz
Operating Channels: 16
