Gendex - GX-770 Intra-Oral X-Ray System
by Gendex
Gendex GX-770 Intra-Oral X-Ray System
FORUMSView All (5)
-Town Center
Sat Aug 16 2025
manual
looking for the exposure chart from manufacturers manual
Equipment: Gendex - GX-770 Intra-Oral X-Ray System
-Amitiss Nasiri DDS
Tue Aug 15 2023
exposer button not working
The exposer handle was dropped and now the exposer button doesn't work . I had some one come and check it and he is stating the entire unit needs to changed ?
-thaioak
Mon Jul 17 2023
GX770 Need to know plug in location for hand switch
Can you please tell me where to plug i8n the terminals for hand switch in the Gendex GX 770
Thank you
Linda Thai
  • Positionable arms
  • 70kVp 7 mA
  • 0.6mm focal point, and 74" total arm length
  • Automatic line-voltage compensation
  • Compatible with all digital imaging systems
  • Unique “Quickset” controls on tubehead
  • User friendly operator control
  • Operator control panel can be mounted on the unit or remote mounted on a wall outside of the operatory for ease of use
  • 65 KV DC for optimized gray scale
  • Reduced soft radiation to your patients
  • Preset anatomical time settings
  • System can be programmed for type of film
  • (D,E,F speed) or type of digital unit used
  • 0.4 mm focal spot for maximum sharpness
  • Line voltage:
    115-130-110-115V
  • Peak tube potential:
    70 kVp ± 10 kVp to 68 kVp ± 10 kVp
  • Tube current:
    7 mA to 6.5 mA
  • Exposure time:
    Within ±2 pulses of selected value
