Impact Instrumentation - UniVent 754
Portable ventilator
The Impact Univent Eagle 754 is completely self-contained and requires no outside gas. Featuring an internal compressor and blender, it offers PEEP with controlled assist, SIMV, Intubated CPAP, and CMV (for apnea backup) ventilation modes. Bright graphic LCD provides monitoring and alarm settings. An interactive demo/teaching mode assures fast start up sequence in as little as three steps. EMI/RFI and Air Medical certified
FORUMSView All (3)
1Reply2 years ago | Service Manual HI, im looking for a UniVent 754 service manual. Please let me now if some one has it. I need this asap! Thanks Reply |
1Reply4 years ago | Pm hours reset and laptop connection How do I connect to my laptop to perfom the reset? Which software is required on my laptop?Reply |
0Replies4 years ago | How to connect the impact 754 to a laptop What software application is required on the laptop ??Reply |
- Deliverable Gas(es) Air (Internal Compressor, External 50-PSI); Oxygen (External 50-PSI)
- Tidal Volume Range 0 to 3000 mL
- I:E Ratio 1:1 Preset, Adjustable 1:1 to 1:599
- Sensitivity Default, 1.5 to 2.0 cmH2O; Adjustable, 1.0 to 6.0 cmH2O
- Flow Rate Adjustable, 0 to approximately 60 LPM (0 to approximately 1000 ml/sec)
- Ventilation Rate Adjustable, 1 to 150 bpm, in 1bpm increments (±1 digit on the display panel)
- Inspiration Time Adjustable, 0.1 to 3 sec, in 0.1 sec increments (±1 digit on the display panel); 1:2 I:E RATION preset
- FiO2 Adjustable, 21% to 100% (Internal Air/Oxygen Mixer), resolution in 1% increments, accurate to within ±10%
- Low Pressure Alarm Adjustable, 0 to 50 cmH2O, in 1 cmH2O increments (±1 digit on the display panel)
- High Pressure Alarm Adjustable, 15 to 100 cmH2O, in 1 cmH2O increments (±1 digit on the display panel)
