CME - T34
Syringe infusion pump
The T34 is a small, lightweight, robust, battery powered, ambulatory syringe Pump designed to
deliver the contents of a 2 to 50ml syringe over a specified duration or at a given rate in
milliliters per hour (ml/hr). The Pump actuator drives the syringe plunger forward at a controlled
rate. This rate is adjustable from 0.1 to 1000 ml/h in increments of 0.1 ml/h up to 100 ml and 1
ml up to 1000 ml/h
1Reply2 years ago | Access code Hi everyone, is there anyone who could send me the access codes for a CME pump model T34? Thanks in advance for your help!Reply |
- Automatic syringe detection
- Multi-program infusion
- Programmable flow rates
