LifeScan - OneTouch Select
The OneTouch Select Meter is for people who want testing to be easy and accurate. It features simple on-screen directions and a large, easy-to-read.The OneTouch® Select™ Meter uses OneTouch Select Test Strips (OneTouch Ultra Test Strips won’t work with the OneTouch Select™ Meter). Test results with the OneTouch®Select™Meter are plasma-calibrated. This helps you and your health care professional to compareyour meter results with laboratory tests. If you have been using another type of meter—one that provides whole blood-calibrated results—you may notice that your test results with the OneTouch®Select™Meter are approximately 12% higher. OneTouch®Select™Meter test results and laboratory test results both are expressed in plasma-equivalent units. However, your meter result may differ from your laboratory result due to normal variation. Meter results can be affected by factors and conditions that do not affect laboratory results in the same way. Your OneTouch®Select™Meter glucose value is considered accurate when it is within ±20% of the laboratory measurement.
2Replies4 years ago | Changing the unit of measurement Please how could I change the unit of my machine from mg/dL to mmol/L? Thank you!Reply |
[list] [*] OneTouch Select Blood Glucose Meter (battery included) [*] OneTouch Lancing Device and Lancets [*] OneTouch Owner’s Booklet and Starter Guide [*] Logbook [*] Carrying case [*] The OneTouch Select Meter uses OneTouch Select Test Strips and OneTouch® [*] Select Control Solutions, which are sold separately. [/list]
Height | 3.54 in |
Length | 0.85 in |
Weight | 1.8 oz |
Width | 2.19 in |
[list] Reported result range: 20–600 mg/dL Test time: 5 seconds Memory: 350 blood glucose or control solution test results Hematocrit: 30–55% [/list]
