AccuVein - AV400
by AccuVein
Vein viewing system
The AccuVein digitally displays a map of the vasculature on the surface of the skin in real time, allowing clinicians to verify vein patency and avoid valves or bifurcations. It is handheld and lightweight, weighing only 9.7 ounces (275g), and easily converts to hands-free with the use of optional wheeled or fixed stands. The medical grade design allows the device to be easily wiped clean, bagged for use in isolation, and does not require calibration as it is permanently aligned. The easy to use AV400 can be held in any direction above the vein being viewed. Universal and inverse modes make the AccuVein useful on a variety of patient types. With center line accuracy to the width of a human hair, the AccuVein can detect veins up to 10 mm deep. More effective venipuncture procedures with less patient discomfort result in higher patient satisfaction, making it clear why many facilities have chosen to incorporate AccuVein into their standard of care.
0RepliesInvalid Date | Persistent low temperature display Increase the room temperature as manual but not remove it. Please help me thank you. Accuvain AV 400 vain viewer |
1ReplyInvalid Date | AccuVein- AV400-500 GM, I am looking a service manual for the AccuVein. Does anyone have a copy available? Reply |
0RepliesInvalid Date | Error Code 028 Hello. I am using AccuVein - AV400. After booting, the machine reported error 028. Please help me, thank you. Reply |
