Air Techniques - A-T 2000
by Air Techniques
Film Processor
Process Time: Archival, 5 1/2 minutes. "Quick-look"Endo periapical films, 2 1/2 minutes
Chemistry Replenishment: At initial power on, 4 1/2oz. in 90 seconds. Every 12 3/4" linear film, 1 2/3 oz. in 35 seconds
Water Flow: 1/2 gallon per minute (while processing film). Do not use water softeners
Water Pressure: 80 psi max. / 30psi min.
Water Connection: 1/2" female NP and 3/4" male garden hose adapters provided. A 6' long water supply hose is provided to connect to the rear of the processor
Water Backflow Prevention: Vacuum breaker not required. Processor has a 1" air gap between water supply inlet and top of highest water level in processor
Water Temperature: Mixing valve not required if water temperature is between 55 degree F (13 degrees C) to 80 degrees F (27 degrees C)
Dimensions: 18"x15"x25" with leveling base. With Daylight loader, 18"x16.25"x39"; Daylight loader extends additional 10.25" below counter top
Weight: 90lbs with water and chemistry, 75lbs empty
