Roche - ACCU-CHEK Aviva
by Roche
Less retesting. More confidence in the results. The easy, quick-fill test strip fills quickly with a tiny drop, helping 97% of testers fill correctly on their very first try. And 198 system integrity checks help detect and prevent unreliable results.
Least-painful lancing technology. The ACCU-CHEK Multiclix lancing device uses unique technology that minimizes painful side-to-side motion. And it uses a load-and-go drum of 6 preloaded lancets—no individual lancets to see or handle.
The ACCU-CHEK Aviva meter and strips and ACCU-CHEK Multiclix lancing device comprise the first complete system to receive the Arthritis Foundation's Ease-Of-Use Commendation. The system has an easy-to-use grip and helps you test right the first time.1 In independent lab testing, the ACCU-CHEK Aviva system was found to help people living with arthritis check their blood sugar easily.
Height | 94 mm |
Length | 22 mm |
Weight | 60 g |
Width | 53 mm |
Memory capacity: 500 results with time and date
