Roche - ACCU-CHEK Active
by Roche
The ACCU-CHEK Active system makes checking blood sugar easy, by giving you the choice to dose with the test strip in or out of the meter.
-Reem
Invalid Date
Problem
Dear Sir,
I have a problem regarded the accu check active meter , the reading is change per test.
please advice ,
[list]    [*] Quick, 5-second results—10 seconds if dosed outside the meter     [*] Choice of 6 test sites on the body2     [*] Downloadable 200-value memory with 7- and 14-day averaging     [*] Small 1.0 microliter sample size     [*] Uses 1 readily available 3-volt lithium coin cell battery     [*] 1,000-test battery life    [*] Compatible with ACCU-CHEK data management tools     [*] Preferred on most healthcare plan formularies, so you may save money  [*] Flexible dosing in or out of the meter - apply blood to the test strip in the way that's easiest for you.     [*] Least-painful lancing device - won't tear your skin by wiggling from side to side.1 Plus, the Comfort Dial offers 11 depth settings to match your skin type.     [*] User-friendly handling - a large display, simple handling with just 2 buttons and an easy-to-hold design.  [/list]
Height4.6 in
Length 0.9 in
Weight57 g
Width1.7 in
[list]    Measuring range: 10-600 mg/dL     Sample size: 1µL     Measuring time: Approximately 5 seconds    Memory capacity: 200 blood glucose results with time and date    [/list]
