Comed - EVA - HF325, 525
by Comed
High frequency radiography x-ray system
-Pedro Lopez
Fri Jan 26 2024
Biux2x2
Cual?
Tube forward and backward movement range : 185mm
X-axis center rotation angle range : over ± 90°
Z-axis center rotation angel range : over ± 90°
Ttube max upward movement : above ground 1720 mm
Tube max downward movement : above ground 650 mm
Tube up and down movement range : 1170 mm
Tube left and right movement range : 1940 mm
Table forward and backward movement range : 200mm
Table left and right range : 600mm
Total weight : 430 kg
