UMG/Del Medical - CMP 200
X-ray system generator
The CMP 200 X-ray generator is intended for use in stationary radiographic X-ray systems, including tomography. The X-ray generator consists of a main power cabinet, and a control console. The main power cabinet contains the HT tank and control circuits, the filament drivers, the low speed starter, and interface connections to the room equipment.
FORUMSView All (4)
0Replies5 months ago | The conteol console does work , only the first button is in use What can i do to solve this problem ,buttons are non working properly Equipment: UMG/Del Medical - CMP 200 Reply |
0Replies5 months ago | Problem typing the control console cmp 200 am having problem with control console, sometimes it works fine using and changing into deferent menu, but the most time the buttons dosent respond , the only button that always respond is the firat one which indicate cervical menu, what should i do to solve this problem? Reply |
2Replies3 years ago | Wall Bucky Intermittent issue Hi does anyone know why the wall bucky my have trouble locking into place intermittently? The issue usually only occurs when a case is open. Works fine when there is not patient case.Reply |
Integral low speed starter, compatible with X-ray tubes with type “R” stator. Optional compatibility with GE 23/23 Ω equal impedance “E” stator.
24 VDC, 110, or 220 VAC power source for Buckys.
24 VAC 150 watts power source for collimator lamp.
24 VDC 45 watts power source for system locks.
Optional AEC.
