Roche - ACCU-CHEK Advantage
by Roche
The ACCU-CHEK Advantage uses unique ACCU-CHEK Comfort Curve diabetes test strip and least-painful lancing technology.
-angelagail
Mon Apr 02 2012
program code
I need help programming the code, its an older model and only has an on/off button
[list]    [*] Downloadable 480-value memory with time and date       [*] Uses one readily available 3-volt lithium coin cell battery    [*] Compatible with ACCU-CHEK data management tools       [*] Preferred on most healthcare plan formularies, so you may save money       [*] Easy handling. The small design is about the size of a stopwatch, with rubber side grips.    [/list]
Height3.3 in
Length 0.8 in
Weight1.8 oz with battery
Width2.2 in
Memory capacity: 480 test results with time and date
