Kontron Medical - Imagic Elite
IMAGIC ELITE is an open and flexible platform with cutting-edge innovation and architecture that provides a new level of diagnosis confidence.FORUMSView All (3)
0Replies4 months ago | Error type 28 hardware problem Hy everybody, I have a SIGMA 5000 IMAGIC ELITE Echo and i do not access to exams because the machine is stopped during loading process for type 28 error (DUU FPGAs cannot loaded). What is the probelm? Is possible to resolve it? Thank you so much Reply |
0Replies3 years ago | Manuals Does anyone have any manual for the imagice elite 5'000. I found one at my new job, and the documents are missing, it has a blinking green light, and system is not booting.Reply |
0Replies10 years ago | TEE PROBE OF KONTRON ELITE HI IS TEE PROBE OF KONTRON ELITE COMPATIBLE WITH KONTRON AGILE? Reply |
[u]Advanced ergonomics and smooth workflow[/u]
- Its unusual design, its incredible power and its ergonomics make it easily adaptable.
- Open and complete digital architecture,digital beamformer, FPGA based
- An innovative new digital beamformer provide a clean image that is virtually artifact-free and absolutely homogeneous, even in deep scans.
- Golden probe with superior large bandwidth for better image quality, sensitivity and signal/noise ratio
- A new generation of wide-band multifrequency transducers will help users, even in the most complex diagnostic cases, or with hard-to-investigate patients.
[u]TEM (Trans-Esophageal Multiplan motorized phase array)[/u]
- A truly innovative transducer with the motor in the tip of the endoscope to reduce number of cables for a high movement accuracy is ready to support the future application like 4D.
- TriaX and Smart Harmonic for excellent B mode and M mode image quality
- The three-dimensional non linear filter elaborates the pattern of every single frame at the pixel level, eliminating speckle and noise artifacts and delivers very fine 2D images and high resolution M mode.
[u] Digital Multi-beam Processing and FCI Compound Technology Imaging[/u]
- An innovative compound ultrasound imaging method that includes different acquiring component frames with different scanline properties. It always offers the best imaging features without any compromise with realtime imaging.
- iCFM (intelligent CFM) the state-of-theart technology delivers a higher frame rate, better color resolution and color sensitivity
- High-speed Color Doppler allows a higher Frame Rate in all the Cardiovascular applications.
- ATEC Pro for superb Color Doppler and Power Doppler
- The third generation’s Advanced Tissue Echo Cancellation eliminates the photographic noise of moving tissues and delivers clear sharp information flow on CFM and Spectral Doppler.
- DFC (Dedicated Focusing Control) plus dedicated CW beamformer makes hypersensitive CW and PW
- The Focusing Control is the only possibility to have the best Doppler profile in narrow high-speed and low-intensity regurgitations.
[u]DMAS (Data Management and Archiving System) allows still images and loops archiving in different electronic formats[/u]
- Images are stored in their raw format,allowing off-line measurements at any time after the patient has left. Archived files can be stored on the HD (160Gb), exported on a CD-RW or archived on an external HD.
[u]Fully integrated communications – TCP/IP– DICOM 3.0[/u]
- But being in a class of its own also involves some things that might seem to be mere details: the unexpected speed of execution, the use of the PC Windows operating system which connects users to the entire world, the digital peripherals, and the connectivity of DICOM service classes. The USB capability is today the “Elite” connectivity for PC printers, Storage media and the new networking features.
Cart Based | 1 |
Height | 1200 mm |
Length | 759 mm |
Clinical Applications | Colorectal |
Doppler Modes | Spectral Doppler |
Image Display | 15 in active matrix LDD flat monitor |
Imaging Mode | B, B/M. M |
Width | 600 mm |
