Quanta Aesthetic Lasers - Thunder
High power laser for skin rejuvenation and hair removal.
1Reply3 years ago | service manual for quanta thunder mt laser machine can you send me the service manual for quanta thunder mt laser machine Reply |
0Replies4 years ago | Supply Overtemp error #10 Hello I need some help, I have been getting supply overtemp errors with some Quanta Thunders (Duetto's Successor). The problem occurs with the ALEX when the scanner attachment is attached (fast beats) and at 14 Hz (maximum). Then a "supply overtemp" error shows up, after the laser has shot around 3000 beats. First I replaced the thermo switch, which didn't solve the problem. Then I replaced the flash lamp which improved the voltage, but the error still occurred, so I tried replacing the charger. After all this, the error message still showed up. Can I get any advice on what to try next?Reply |
